Perhaps then I'm just expecting too much from the inbuilt HDR on the K-7 and I should stick to more old fashioned methods and manually experimenting with HDR on a PC with photoshop
What really surprises me is that there are no 'options' as such with it. Ie if you're in standard JPEG mode then you have all sorts of bracketing options - both exposure bracketing and extended bracketing. So what you can do is set the thing up to a) bracket 5 shots and also for each of those 5, have the inbuilt 'extended bracketing' then create 3 variants with either white balance, saturation, hue, high/low key adjustment, contrast or sharpness 'bracketing'. Ie giving 15 variants in all.
But with HDR capture on, both extended and regular bracketing seem to get disabled. Which really rather surprises me because it doesn't seem to deliver the automatic variants that I'd like in order to make a choice/get it looking better
in-camera. Sure I can always do that on a PC but that's not really the point?
Also, I'm kind of surprised that inbuilt HDR requires more than one exposure. That means it requires a tripod which limits its use to smucks like me that don't mind carrying a tripod about. After all, light entering a lens is just a data stream really. So why not implement it in a way that requires just 1 shot, and have the internal processor then do its business and divvy them up internally. I'm not really being clear here, let me explain.
Ie say for the sake of round figures I have a 1 second exposure recommended. Then presumably HDR needs 2 seconds for the lows and 1/2 second for the highs. So it takes a 2 second exposure only. During that 2 second exposure, after 1/2 a second it takes the data and calls it number 1 internally. Then after 1 second it takes the accumulated data (which will also contain the previous 1/2 second) and calls it number 2 internally. Then when we've reached 2 seconds it calls the final one #3 internally. Then it'd use those 3, do it's HDR thing and call it and HDR image. That'd seem a far more sensible way to implement HDR for mass-usage - because for most shots it'd mean no need for a tripod (ie most shots being say 1/125).
As for HDR itself, yes clearly there are some spectacular results being achieved with it. I'm thinking that rather than use it on situations where I'm expecting shadows and contrast, I should give it a whirl on different subject matter. For example more flat lit still lifes. To me, it seems that HDR actually turns photography on its head a bit. ie instead of photography being a an art that's largely about the light, it almost says who cares about the light, it's about colour and shape. Which is of course fair enough, heck there's no such thing as 'right', it's an interprative art.
