Originally posted by photolady Depends on how much it's compressed there can be jpeg artifacts in the print. Of course most cameras (re digitals) that use jpg/jpeg are better because the pixel sizes are larger. But older scanned film, turned jpg for the web (72dpi) you wouldn't want to print those. Sorry I didn't think about this idea in the main. I was seeing jpegs printed at 72dpi.
I'm still going print some in png to see how they differ.
Yeah, I'm guesisng it was the loss of resolution in saving for the web that is the problem here. Sure, in a large enough print, you could take a magnifying glass to it and see JPEG compression artifacts if you knew what to look for. But the loss of resolution if you're saving for web - that's what's jumping out and grabbing you by the throat, not the JPEG compression. A JPEG saved at full resolution at a reaosnable high quality / low compression ratio would be very unlikely to cause any issues you'd notice.
BTW, when I say "full resolution", think in terms of number of pixels, not dpi - the latter does nothing but cause people confusion. "dpi" is relevant when actually performing the can, because it instructs the scanner on how many pixels to collect. But once you've collected the pixels, it becomes irrelevant. If you concentrate on always keeping the number of pixels you've collected, it won't matter what the dpi number in the file says. Printing X pixels at a size of Y inches works out to X/Y dpi, regardless of what the dpi in the file says. It could *say* 4000dpi, but if you've only got enough pixels for 72dpi, then 72dpi is all you'll get. Conversely, it might *say* 72dpi, but if you've got enough pixels for 300dpi, then 300dpi is what you'll get.
In any case, sure, PNG, will give slightly better results than JPEG because its compression is lossless. File sizes are of course correspondingly bigger, and there's no support for most metadata, but neither of those should be issues for images generated for the sole purpose of printing (assuming you are using TIFF as your "native" format).
