10-21-2009, 07:42 PM   #1
mba1971's Avatar
Post production software / wich is the best?
So lest suppose I want to buy a post processin program. Wich one is worth the money and investment in time ( to master it)?
10-21-2009, 08:45 PM   #2
Wheatfield's Avatar
Adobe Photoshop.
The learning curve is huge though as it is a very big program.
10-21-2009, 08:57 PM   #3
graphicgr8s
Guest
Don't forget to join NAPP. Lessens the learning curve.
10-22-2009, 02:33 AM   #4
Class A's Avatar
QuoteOriginally posted by mba1971 Quote
Many photographers seem to prefer Lightroom over Photoshop. Less possibilities but typically sufficient.
I'm not a great fan of these fat Adobe programs which are expensive and not easy to use. Bear in mind though that my experience stems from CS3 or even earlier, not sure. I could handle other Windows software blindfolded, but Photoshop set me back to beginner mode for the most basic actions. It was a royal pain to use. It may well be that later versions and in particular Lightroom have a better user interface by now.
Has anyone compared free software like "The Gimp" and "RawTherapee" to Photoshop and Lightroom respectively?
What is one missing out by using the above free software?
10-22-2009, 10:38 AM   #5
deejjjaaaa's Avatar
PP means layers, masks and so on and plugins that can save you time & effort... nothing gets close to what is available in/for PS so far if you want to do a heavy PPing...
10-22-2009, 10:42 AM   #6
Eruditass's Avatar
Lightroom is great for 99.999% of images and I find it very easy to use and non-destructive - even better for beginners. I recommend it over PS.
10-22-2009, 12:13 PM   #7
philbaum's Avatar
Depends on your personal goals, fit and preferences.
If you are just starting out, i'd recommend Adobe Elements. Usually about $100 but some box stores like Costco have occasional sales on it for as little as $49. Some folks say it has 95% of what Adobe Photoshop has. One of the best parts is one can get pretty sophisticated with it by learning layers and also its uses most of the plugins available to Photoshop. I currently use the Topaz Denoiser as a plugin for it and its GREAT.
Then later on, if you wish, you can migrate to Lighroom (which is designed to interchange photos with Elements for the things that LR can't handle, or can migrate to the full Photoshop).
Best wishes
10-22-2009, 12:31 PM   #8
Marc Sabatella's Avatar
I find the GIMP to be as daunting as Photoshop, personally. I've only taken a breif look at RT, but it doesn't provide the same sort of integrated browsing/organizing/parametric-editing environment that LR does.
I'd say Photoshop or the GIMP or similar programs are both well suited when you intend to spend a long time doing a lot of things to each photo. The strength of programs like LR - also Aperture, ACDSee Pro, and Lightzone - are more in the abiity to *quickly* process many files.
10-22-2009, 03:55 PM   #9
Class A's Avatar
QuoteOriginally posted by deejjjaaaa Quote
GIMP has layers, masks and plugins as well. What essential functionality is offered by PS that GIMP doesn't have?
I've only taken a brief look at RT, but it doesn't provide the same sort of integrated browsing/organizing/parametric-editing environment that LR does.
That's my main gripe with RT (RawTherapee) and the reason why I use Picasa most of the time, only resorting to GIMP and RT when a particular image requires more than Picasa offers.
10-22-2009, 04:10 PM   #10
deejjjaaaa's Avatar
take a list of plugins available for PS vs the same for GIMP... not just a raw count - but features... did production version of GIMP manage to achive any real usability w/ 16bit images ? and do not try to fool w/ the word essential - you can do everything just w/ gcc compiler in hand... essentially it is enough to do anything w/ the image
10-22-2009, 04:15 PM   #11
deejjjaaaa's Avatar
QuoteOriginally posted by Eruditass Quote
you probably know that PS can do non-destructive too
10-22-2009, 04:16 PM   #12
Whatever you can afford and use properly is the best. It's no use getting Photoshop if you can't use it. Corel Paint Shop Pro can do just about everything Photoshop does at a fraction of the cost. But it's RAW converter isn't too hot. Elements can do just about everything a photographer might wish. And so can a lot of other software, so get what you can use comfortably without breaking the bank, and have fun.
10-22-2009, 11:02 PM   #13
I use Corel Paint Shop Pro X2 and Raw Therapee, Brilliant and a quarter of the price of PhotoShop
10-22-2009, 11:12 PM   #14
Class A's Avatar
AFAIK, there is a 16-bit branch of GIMP, but it is less capable. I believe there is work being done on expanding GIMP to 16-bit but I don't know how far they are.
I had not intentions to "fool" but I also don't think it is useful to count the n-th version of a "water ripple effect" plugin that no one in their right mind would actually use. There are a few essential things like layers, tone control, channel mixer, sharpening, blurring, doding/burning, etc. that need to be supported well. What else do you need? A "toy camera" effect? I don't.
10-23-2009, 07:14 AM   #15
There is no *best* and a full version of Photoshop is not necessary, over kill and a waste of your time to learn. It is really a program for graphics designers. It had no competition for years. It has plenty now and are much easier programs to use. Most of the *free* programs lack good documemtation.
All PP programs have free trials. Check 'em out.
I use the programs below. YMMV.
Silkypix is a great RAW/editing progam. If you try it buy the $5 e-book....well worth the cost.
ACDsee is worth a look.
Photoshop Elements..but *I* don't like the ACR interface.
Lightroom...I am going to try the 3.0 Beta
I also use plugins from Nik software. http://www.niksoftware.com/index/usa/entry.php
There is no simple answer. Have fun.
photography, photoshop, post, wich
Post production question(s) bluebronco Digital Processing, Software, and Printing 13 08-06-2009 11:01 PM
What post-production software do you use? bluebronco Troubleshooting and Beginner Help 3 08-05-2009 10:10 PM
My Amended Post Production Technique benjikan Digital Processing, Software, and Printing 4 06-24-2009 03:19 PM
Post production time? jeremy_c Photographic Technique 20 12-05-2008 02:31 PM
Post Production Q: How do I getting that bleach bypass look? kveldalf Digital Processing, Software, and Printing 17 11-20-2008 11:58 PM
All times are GMT -7. The time now is 09:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
