Originally posted by rustynail925 What are the advantages of Raw when doing PP? Cant notice any difference when a Jpeg file..
This is a big question and you could spend the rest of the day reading various answers on the Internet. I'll try to give you a short version.
Let me start where I always start: by remarking that you are shooting raw willy-nilly, and there's nothing you can do about it. Raw is simply what the camera "sees." All digital cameras do raw capture. The issue isn't whether you will
shoot raw. The issue is whether you will
save the raw data so you can work with it yourself on your computer, or whether you will let the camera's little processor convert the file to a jpeg for you.
Now, the basic advantage of raw files is that they contain more data than a jpeg can contain - a LOT MORE. A raw file can make finer distinctions in hue and luminance than a jpeg can. When you let the camera convert the raw data to a jpeg for you and you do NOT save the raw file, the camera throws a ton of data away. It's lost forever.
Why is this a problem?
Well, a lot of the time, it is not a problem, for most photographers. The truth is, your camera does a pretty good job of making normal raw-to-jpeg conversions. If you are satisfied with the jpegs your camera creates, well, that's cool. Maybe you don't need to save the raw files. That's still a legal choice!
But just about the only compelling reason NOT to shoot raw is that the files are much larger. And that's not a very compelling reason any more, since storage is cheap. I personally want to keep all of the original raw capture data.
When does it make a difference to me in post-processing? It matters in at least three different situations. No, I'll give you four.
First, when I shoot raw, I can leave the camera on auto-white balance and then fix white balance problems on my computer. You don't have nearly the same latitude to fix white balance problems if you have only the jpeg and if the jpeg's white balance is off. The jpeg represents a kind of "translation" of the original, and if the translation is wrong, you can't really fix it without going back to the original. For me, this is reason enough to shoot raw. I leave my cameras on auto-white balance and I NEVER worry about white balance while shooting.
Second, the raw file gives me more data to work with in difficult exposures, including actual problems. For example, say I overexposed the shot. If I was shooting raw, there may actually be a fair bit of data in the bright areas of the shot that I can recover in my raw processing program by pulling the exposure down. Imagine that there are 100,000 different gradations of shade or color, and that level 100,000 = blown highlight with a loss of data. Now imagine that a jpeg "rounds" the data to the nearest 1000. That means that if there are data points in the raw capture that are around, oh, 99,868, in the jpeg conversion, they'll be rounded to 100,000 and basically blown - irrecoverable. But in the raw file 99,868 is NOT a blown highlight: it's a data point that you can actually work with. So, when there's a problem with the exposure, a raw file provides more latitude for fixing problems.
The third advantage of raw is simply that, having more data to work with is inherently good, even when there isn't an exposure problem. Yesterday I shot a sunset. I got my exposure just right in the camera - by which I mean that I used the right shutter speed, aperture and ISO and I didn't blow the highlights. Now, when I got the raw files into Lightroom, I had a lot more data to work with in the bright sky and clouds than I would have if I had only the jpeg to work with. I was able to tweak contrast and colors a little more finely than I could have otherwise.
The fourth advantage of raw is that, with raw, you have the ability to reprocess your photo in different raw converters, and possibly get better results. Some folks here think that Silkypix does a better job interpreting colors from Pentax raw files than Lightroom does. But Lightroom 3 beta has a new raw processor in it, and it seems to me that it is doing a better job with my raw files - including my old raw files. A jpeg is an egg that's been cooked. You can put salt and pepper on it, or ketchup, or strawberry jelly, but you can't UNCOOK it. A raw file on the other hand is an egg that you cook a copy of; you can go back later and cook another copy of the same egg and it might taste better. SO if you save the raw files, you get a certain amount of future-proofing for your images. Better raw converters in the future may produce better jpeg conversions.
Let me add two more comments.
If you don't save the raw file, you're letting the camera do the raw-to-jpeg conversion for you, using its dinky little internal brain. That dinky little brain does a pretty good job much of the time, but it should be obvious that it simply can't be as precise or subtle as your computer's very big brain can be. How often will this difference matter? Hard to say. But I don't think there's any doubt about the theoretical advantage of doing conversions on your computer. This is really a corollary to point 3 above.
Finally, if you have the raw file, even within the same raw converter, you can try different conversions yourself.
Jpeg conversion is a form of translation, analogous to literary translation. If you're a translator working with a 5000 word dictionary, you can do fine most of the time, translating news stories, letters, and you'll probably do a fine job translating a lot of literature - because in most languages, knowing or recognizing 5000 different words will take you pretty far. What if you're translating high literature, like poetry? A non-English speaker trying to read Shakespeare with a 5000 word dictionary is going to run into a lot of problems. Saving your raw files is like being able to read Shakespeare with the Oxford English Dictionary handy.
Will
