Originally posted by rustynail925 I tried the Noise Ninja NR, It does a good job on noise but it softens the image. Are there any process in which it wont affect the clarity of the image?
Can you guys share your workflow in dealing with high iso noise reduction using LR2.5 and another for NR
Though I don't use LR, I can post some of my own methods in dealing with noise with Noise Ninja in Photoshop. I believe the tools and workflow is the same under the stand alone version as well.
One of the most significant steps in noise reduction is creating noise profiles for your camera. This essentially maps the noise patterns for your particular camera for the noise reduction algorithm thus ensuring the most accurate results possible. Otherwise... all you're left with is a default(one size fits all noise reduction) which is not very accurate.
The second most significant detail issue is that of the noise brush. This tool essentially masks away(or masks in) detail and or noise suppression. So... once you've found a suitable noise reduction setting, you can go over the prominent edges throughout the scene(paint them) and make them all sharp again(works wonders!).
The third and final most significant tool in my process is the contrast and sharpen tools. Which work to preserve detail and color loss in the noise reduction process.
There are of course much more advanced methods to squeeze out better noise control in images, but I find that these three areas are the most significant in getting results that are close to the images posted earlier.
PS. I've found a LR,
Noise Ninja video tutorial here. , which I found actually quite good. I've also found the v2 users guide online with a
tutorial section here
