12-09-2009, 06:30 PM   #1
Opening Photoshop-saved RAW in Photoshop
I've just gotten back from my school's library, where I was using one of the scanners to scan my negatives. I scanned the files directly into photoshop CS3. In retrospect, I absolutely should have saved in tiff, which has worked before, but this time I saved the files in raw. This is Photoshop Raw, not Camera Raw. I assumed that I could open these files back on my home computer (Photoshop CS4), but apparently I was wrong. If I try to open any of the raw files, I get a dialogue box that looks like the one posted below, and if I hit "OK" I'm told something about missing color profiles, then I'm given an image of grey noise (see below). If I change any of the settings in the dialogue box (files were saved at 16-bit grayscale with Mac byte order), I am told that "Specified image is larger than file," and I can't open the image.
What's going on? Why can't I open in Photoshop files that I just saved in Photoshop? Have my past few hours just been a total waste?
12-09-2009, 08:55 PM   #2
ryan s's Avatar
Can you use
File -> Open As... -> (drop down) Raw
Or any other option in the Open As... menu?
12-09-2009, 09:29 PM   #3
I only see options to Open and Open as Smart Object, not Open as.... What version of photoshop are you using? I'm in CS4 on a Mac.
12-09-2009, 10:37 PM   #4
Answer to "have I just wasted my time" from someone on Adobe forums:
"Yep, pretty much unless you know the exact size and can correctly fill out the required dialogs required to open a Photoshop "raw" file. The "raw" format is not, as you've found out related at ALL to Camera Raw. It's really a holder over format from the early years used back when there weren't some file formats available on some computer systems...and yes, you SHOULD have used TIFF."
12-09-2009, 10:49 PM   #5
ryan s's Avatar
I have CS3, and I hope they wouldn't have taken that option away...
You probably don't want to hear it, but that was a "live and learn" moment. It doesn't feel good to waste time so it'll be TIFF from here on out
box, dialogue, files, image, photography, photoshop
Which freeware photoshop alternative can apply photoshop plugins in batch raider Digital Processing, Software, and Printing 1 01-28-2010 10:54 PM
Does Photoshop Elements 8 do raw with K-7? barondla Digital Processing, Software, and Printing 12 12-19-2009 02:14 PM
Opening DNG files in Photoshop jamesL Digital Processing, Software, and Printing 7 01-30-2009 02:30 PM
Does the Photoshop RAW converter work with Pentax RAW Files? mconder Pentax DSLR Discussion 3 05-15-2008 12:14 PM
Photoshop 7.0 and RAW Sprags Digital Processing, Software, and Printing 11 01-20-2008 09:59 AM
All times are GMT -7. The time now is 10:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
