12-14-2009, 07:32 PM   #1
mba1971's Avatar
Pentax Digital Camera Utility 4 problem
Hey!
I installed the forementionned software bundled with my new K7. It worked great.
But yesterday, i tryed to open it and.....BUG! It doesn't open, I only get a windows message sayin the softwarew had a problem and could not open...
Is ther a known problem with other programs?
12-15-2009, 05:45 AM   #2
I've just bought a K-x, installed the program and it develops a windows message stating there's a problem in the program during operation.
Andras
12-15-2009, 06:46 AM   #3
I have the same problem. I used the technical support link on the Pentax web site to report it about a week ago and have received no reply.
Mike
12-15-2009, 07:56 AM   #4
jeffkrol's Avatar
QuoteOriginally posted by mba1971 Quote
Hey!
Seems like an uncommon yet not rare problem:
Things that worked (temporarily at least):
Re: Digital Camera Utilty 4 Crashes on my PC: Pentax SLR Talk Forum: Digital Photography Review
IF a registry clean and reinstall works for you I'd suggest the first thing you do is change all the default folders in the program to ones out of Windows "trouble" zones like "My Documents" or any folders in "My Programs"... just stick
a "RAW" folder on "C" and a "processed" folder. Long shot but what the heck..
12-26-2009, 02:41 PM - 3 Likes   #5
Application Error... ptxutl40.exe
This message appears while launching "Pentax Digital Camera Utility 4", supplied with your new K7 or K-x. Three options are offered: Message to Microsoft, Do not send and Debug. None of them does the problem.
Also the common next steps:
1. Try to launch again
2. Reboot and lauch again
3. Reinstall
4. Installing the update (4.11)
5. Uninstall of DCU4, deleting the programm folder and cleaning of windows registry
Don't waste your time - here is a suitable solution.
My last activity was marking about 200 files with the build-in markers. Without further action i had to close DCU4. From then DCU4 ended every launching in crashing.
A deep quest in XP's own (and normally hidden) folders brought the cause: If you mark pictures DCU4 creates a CheckInfo.ini file. If you rename, delete or empty this file launching DCU4 will work normally... until you mark some pictures!
You will find CheckInfo.ini in folder "<Drive>:\Documents and Settings\<Username>\Local Settings\application data\Pentax\Digital Camera Utility 4>"
Please remember: I'm using Windows XP Home (german edition). Therefore folder names are different from other languages editions!
Good luck
claus
01-22-2010, 08:54 PM   #6
Thank you Claus
I just used this fix and it works! I simply renamed the file as I was a little afraid to just delete it. Anybody else having this trouble -- this will work for you.
Maybe this can be added to a sticky or something?
Thank you thank you thank you Claus
Tim
QuoteOriginally posted by claus Quote
3. Reinstall
Good luck
claus
01-23-2010, 03:13 AM   #7
Arpe's Avatar
Worked for me too. Deleted checkinfo.ini.
01-29-2010, 02:05 AM   #8
foivosloxias's Avatar
Same here !
Thanks so much !
I had just updated my bios on a HP pavilion dv6t win7x64 and I thought that was causing all the trouble.
This should be a sticky.
03-16-2010, 10:26 PM   #9
I just wanted to give this athread a bump because it just saved me much frustration, and I thought it may help someone else.
03-25-2010, 11:57 PM   #10
[langtitle=el]I have promplem[/langtitle]
I have the same promplem when i use this program can anybody from pentax help us???????????????
03-25-2010, 11:58 PM   #11
i have the same promplem when i use this program can anybody from pentax help us???????????????
05-23-2010, 06:51 AM   #12
rodfs's Avatar
I had this problem but claus' fix worked easily. thanks!
06-24-2010, 07:15 PM   #13
3. Reinstall
Good luck
claus
I dont have a local settings folder. Windows XP. I tried a search as well and was not able to locate the file folder that is recommended for deletion or renaming...thoughts???
Thanks!
06-25-2010, 07:11 AM   #14
QuoteOriginally posted by Lucas Quote
Thanks!
Just got off the phone with Pentax. You do not need to reinstall or even upgrade.
There's a bug in the program that causes it to crash if you exit the program while any photos have a check mark in the box.
Take all of your photos and move them to a new folder (do NOT name the folder PENTAX). I called mine K-X.
Delete the original folder and relaunch the program.
Worked perfect for me
08-30-2010, 01:42 PM   #15
...ha funzionato rinominare il CheckInfo.ini anche con me
thanks
camera utility, pentax digital camera, photography, photoshop
Pentax Digital Camera Utility 4 tom_kkh Troubleshooting and Beginner Help 24 11-25-2012 02:28 PM
Problem with digital camera utility 4 on mac samski_1 Digital Processing, Software, and Printing 1 05-31-2010 03:56 PM
Pentax digital camera utility v 4.11 problem tomas99hagberg Troubleshooting and Beginner Help 4 05-30-2010 07:20 AM
Pentax Digital Camera Utility 4, K7 and Lens corrections problem Labuzan Digital Processing, Software, and Printing 2 12-28-2009 10:09 AM
Digital Filters in Pentax Digital Camera Utility 4? lawsonstone Digital Processing, Software, and Printing 0 07-19-2009 04:44 PM
All times are GMT -7. The time now is 11:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
