I must confess I can't remember how I installed photoprint myself, whether it was from the tarball or repository, but have you tried 'sudo apt-get install photoprint' ?
As regards replacing the printer, although I have much preferred HP and Canon printers in terms of usability I came to the conclusion that on Linux there is better support for Epsons, and you obviously can't fault the print quality their better models can reproduce. I can't recommend doing the same but I took a big chance and bought an r2400 with blocked nozzles on ebay and managed to free them up, just stumping up the cash and getting a new r2880 would be more sensible. I am using a Lyson CIS and their inks - which I can unhesitatingly recommend if you are prepared to use their (provided) profiles, this is necessary as they use their inks to best advantage, exceeding Epson colour gamut in places, rather than attempting an exact match with no profile adjustment.
I'm running Ubuntu 64 bit as well but still at 9.04 on my main host with photoprint. I do however have 9.10 running in 9.10 64 bit virtual guest so, if all else fails, I could try to compile it and ship you a binary from 9.10. It is worth some effort to get photoprint operational.
