The crop that was resized in PF ended up as 600h x 480. Assuming it was originally 800px wide as you stated, that makes the original crop dimensions 1000h x 800w. Now there are four ways to show images on this site.
1. Attachment at end of msg. This is what you did as it said "Attached Images". Unfortunately the max. size is 900w x 600h. Since you attached an image that was higher than 600px, it resized it to 480w x 600h.
2. Embedded within msg from Album (max. 1024 x 1024) or Gallery (no limits - greater than 1000w, better to link thumbnail to album, rather than show album original - users don't like scrolling horizontally to read text in a forum message that is super-wide due to the presence of extra-wide embedded/linked images).
3a. Linked within msg, using the IMG tags in the Enhanced PF WYSIWYG editor, from your external web space.
3b. Linked within msg, using the IMGWIDE tags in the Enhanced PF WYSIWYG editor, from your external web space. Reduces width to 640x. Click on image to see larger version. Larger version is limited to max. viewable area in browser - no scrolling. Also display resizing method is quick, but low-quality, so diagonal lines can end up jagged.
Here is a test image of that size (1000h x 800w - it's only 16KB) to show when the file will be resized:
1. Attached at end. Because the max height is 600, the image is resized to 480w x 600h.
2. From Album.
3a. IMG tags. I cut & paste the URL to the cropped image situated on my personal web space & enclosed it within IMG tags in this forum message to get:
{IMG}http://users.on.net/~dosdan/Crop%20Example/test_image.jpg{/IMG}
except I actually used square brackets "[]", instead of "{}".
3b. IMGWIDE tags. No shown here. More suited to wide images than tall image.
Dan.
