Originally posted by Dom You can run PhotoShop under Linux if you want, you'll have to use virtualization through. Also if you want I'll start slagging of you chose of OS as well.
Hey, unless I missed something, you already did in your first post.
As for GIMP. Call me back when the guys working on it get beyond an 8-bit color space.
Cinepaint is better on the color space issue, but still is kind of half-assed for a RAW processing pipeline.
As for color management on linux, unless it got a lot better recently, what is the point if I have to have other OSes installed to generate ICC profiles?
To the OP:
If you are using a lot of scratch disk when editing in PS, you want more ram. It'll beat more processor as your processor just sits there being bored waiting for transfers to/from disk as the disk is WAY slower than everything else in the system. For example, I was using CS2 on a 2.4ghz X2 processor with 2GB of ram. Using smart sharpen was SLOW, literally 30-40 seconds per image. On a 3.2ghz i7 processor with 6gb of ram, no more swap and it takes about 5 seconds to process. From some testing I did, I'd guestimate that more ram would take the old machine from 30-40 seconds to about 10-15. The difference between 10-15 and ~5 seconds is likely less due to clock speed, and more to do with 2 additional cores and a a MASSIVE increase in memory bandwidth with the i7 architecture. (from watching the machine, smart sharpen seems to be multi-threaded and thus takes advantage of multiple cores).
If you are NOT using a lot of scratch disk to process images from your camera, then more ram won't do much good. At that point you want more CPU, and preferably one with good memory bandwidth as you will be moving lots of data from system ram to the CPU cache and back.
To the guy who said don't forget the video card:
Performance increases from video cards only really applies to photoshop CS4. Even then it is a VERY small set of features that do not really represent image processing so much as interaction with the GUI. It is perhaps the least result for the most money with regard to photo editing. The only other thing a video card is going to affect is display quality, and that is going to be more about the quality of the signal path on the video cards. IMO if you stick with the $150 and greater cards from either ATI or NVIDIA, and calibrate, there is very little difference.
