Originally posted by graphicgr8s Why are you bringing it in as a smart object?
It sounded like a smart choice. I'm not really sure, I thought this would be sure to preserve all the information in the RAW file.
Quote: If your trying to bring out different effects to each of those things use layer masks.
Yes, I was trying to lower the exposure of the sky while boosting the blues and contrast. Likewise boost the contrast of the foreground to make the diagonal feel stronger. I will read up on layer masks.
Quote: As for the pixel loss try defringe.
I will read up on defringe.
Quote: Or extend your selection by 1 or 2 pixels. INHO you've gone about it in the wrong fashion.
Probably.
Still I don't understand why the pixels are being lost.
I will tell you the exact steps:
a. Layer via Copy of the whole file (call that layer "All")
b. View only the "All" layer
c. Select any portion, let's say the sky
d. Layer via Cut (call that layer "Sky"; "All" layer no longer includes the sky)
e. Now view just the "Sky" and "All" layers
f. Add an adjustment to lower exposure by -10
g. Observe white thin line between the "Sky" and "All" layers
h. If I now merge the "Sky" and "All" layers the thin white line is still there - the merged layer no longer constitutes the whole picture
It seems as if when I did the "Layer via Cut" that it cut all the pixels including the selection line pixels, but it only put the pixels inside the selection (not including the selection line pixels) inside the new layer.
Originally posted by amoringello First; View at 100%.
Yes, I am doing that.
Quote: Next; Not sure of your exact steps, but if there is an actual break... try using a layer mask to hide the parts you do not want.
That sounds to me like working around the problem. I'm hoping it can be avoided in the first place.
Quote: Dunno how proficient you are with PS. If this doesn't make sense I'm sure you'll ask, or someone else will fill in the terse bits. :-)
Thanks. I'm not proficient at all.
I was just expecting that if I cut a layer out and then merge it back in I'd end up with what I had initially. Seems like that's not the case.
