I am working with a set of images taken in a difficult lighting condition - sunset, as a 2x15 (2 rows at 15 images each). Essentially, I would like to give preference to the top row of images over the bottom row of images. There is approximately 20% overlap of the rows.
The reason for this is that to top row is primary sky (sunset), with the bottom row being a silhouetted landscape in the evening with valley lights. The problem I am having is that when stitched, there are a number of images in the bottom row that are essentially overlaid over the upper row, that creates a block effect. The images in the top row effectively are much clearer for the sunset sky view.
I just added an example image that shows the problem. If you look at the sky immediately above the hill tops, as compared to the sky further up in the stitched image, you will see that the area just above the hill tops is a bit more "muddy", and not as clearly defined as the area above. This is produced in the rendering stage. Actually, using the reduced size, you can actually watch the batch renderer overlay the desired section of the image. An example of this is right in the center at to top of the hill, the top row segment took priority, and as a result, you have a good sky at the horizon.
So the question is that I am using a trial version of AutoPano Pro 2. Does anyone know if another stitcher does multiple rows and provides some user input in terms of what may appear on top?
I am in the process of going through and down loading trials after reading the websites, however there is not a lot of information on this particular aspect.
As long as I am on the topic here, I also find that during rendering, the bottom row pushes the renderer to darken the entire stitched image. The sky is much brighter than what is indicated by the result.
Thanks!
