An easy way, providing they are all formatted the same, is to do a contact sheet, with the dimension being 4x6 and one file per sheet.
It will print the filename below the image.
Here's the settings:
Units: Inches
Width 4
Height 6
Resolution: match to the printer, or 300.
RGB
Flatten: checked
Thumbnails: place column: Doesnt matter, leave it at whatever it's set to.
Check auto spacing
Columns 1
Rows 1
Check auto spacing.
This gives a white border on the sides and a file number on the bottom with an out of camera file.
Edit: I just wrote an action that you can use to do this as a batch using the above method.
PM me if you are interested with an email address that I can send it to and you can have it.
