04-03-2010, 01:22 PM   #1
Batch Conversion/Extraction DNG to JPEG?
Hi,
just left the DSLR passion back to ordinary P&S camera Panasonic TZ7, I need to EXTRACT JPEG image from Adobe-DNG format.
I've several thousand files to be converted, all reside in a recursive Windows folder structure.
I'm looking for an EASY tool! Selecting the image root directory and PROCESS with high speed (it's just extraction, no processing).
I've tried IrfanView but wasn't happy with the UI.
Digital Photography - RawWorkflow.com - Instant JPEG From Raw Utility will do the job, but NOT recursively.
Any good freeware out there? Best regards
04-03-2010, 07:05 PM   #2
Not sure why you don't like Irfanview's UI, but it is has one of the easiest batch conversion utilities out there. FastStone has a very similar setup (sometimes I think it's borrowed concepts from IrfanView), and there are a few others.
If you let us know what you didn't like about IrfanView, perhaps we can make better suggestions.
04-04-2010, 08:32 AM   #3
Imagemagik has a conversion module that is quite fast. It's used from the command line, but once you get a handle on it's tags it actually pretty easy to use, is pretty fast, and gives you full control of your conversion. Their site lists several programs that used Imagemagik as a core, so one of those might have a GUI if the command line is not to your liking.
image, jpeg, photography, photoshop
Linux: batch raw conversion script w/ ISO-dependent processing Quicksand Digital Processing, Software, and Printing 8 07-14-2016 11:53 AM
Help! Batch Conversion - from .dng to .jpg J.Scott Digital Processing, Software, and Printing 9 02-06-2010 04:03 PM
Batch DNG>tif Conversion dadipentak Digital Processing, Software, and Printing 17 12-11-2009 11:56 AM
ufraw and imagemagick batch conversion (k10D) uffe Digital Processing, Software, and Printing 9 09-01-2009 01:54 PM
Batch converting camera dng to acr dng using acr Maynerd Digital Processing, Software, and Printing 6 01-17-2009 02:22 PM
All times are GMT -7. The time now is 06:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
