Originally posted by patrickw Chris, incidentally I posted a couple of days ago some RAW images developed in both Aperture 2 and Lightroom 2 in the thread in this forum about "Pentax skies seem too green" (or something along those lines...). If you look at those pictures, that will give you some idea of how two different pieces of software can indeed render the same RAW file in slightly different ways... and maybe it will give you some idea which one you like the looks of better, or even if you care about those sorts of relatively small differences.
I've been following that other thread and have been looking into raw conversion a bit. You'll get the most accurate conversion with a custom profile. Adobe Camera Raw, Apertute, Bibble and CameraOne all allow you to create one. Once you do that, including white balance, the color results should be close to identical.
The problem is that no generic profile will fit each camera. Even two models of the same camera may have slightly different color curves. So my K20D may be slightly different from yours. Lenses definitely introduce white balance differences too. My 18-200 is slightly warmer than my 100 mm macro. My 50 mm 1.7 registers between them in temperature. Also each camera model will react to different light sources differently. In daylight my camera shifts blue slightly towards green. Under incandescent lights it doesn't. (Thanks for the pointer, Phil).
Then there's contrast. Aperture's converter introduces slightly more contrast to my PEFs than ACR. The Pentax software looks more like Aperture, but I don't like the workflow for either.
I've been practicing with creating custom conversion profiles for ACR/Lightroom, which gives me a more pleasing conversion than the default one. From what I've been reading, the best profile will come from setting up a custom profile from a calibrated color chart, like you see in dpreview.com. I've ordered one and will see how much that improves my conversions.
michael mckee
My Port Townsend – A City in Photographs – 365
