Originally posted by clarenceclose I found a nice haze buster in Photoshop that can salvage a problem photo.
Open photo, duplicate the background layer.
On popdowns, Image, Mode, LAB
Once converted to LAB mode make adjustment layer, curves
alt click on the background to make the poped up graph 10 squares each way
hold down the alt key and move the eyedropper over your photo while watching the major locations of a hollow bubble on the diagonal curve line.
This will tell you where most of the haze resides.
Click on the diagonal for the curve above where you observed the moving bubble and holding down the mouse button, drag the mouse to the left half a square.
Now go to the lower portion of the curve and pick below where the moving bubble, drag to the right approximately half a curve.
That should have added contrast in the major haze zone.
If not enough, move each dot in its respective direction a little more until it looks correct.
Once done you can turn off the bottom layer and merge visible layers.
Turn back on the bottom layer, Image, Mode, RGB, don't flatten. Now click on the eyeball of the upper layer to see the difference (of course you could have clicked on the curves adjustment layer and done the same) this way you have two versions in the same .psd file.
Let me know if this worked well for you.
Clarence
Hi clarence
thank you for the tip.... I take it when you are in LAB mode you are selecting the luminosity channel to do this?
I will be giving this a shot soon, if I can ever get my wife off my computer with CS2 on it
cheers and thanks again
