Originally posted by tjk911 Just checked and it's the 360B, is that a good one or...?
Also, any idea how I can remove the teleconverter? I mounted it on in curiosity (before I even knew what that lens was, never seen an adaptall) and can't seem to get it off.
And and! The aperture of the teleconverter does not align with the aperture of the lens (lens set at f2.8, teleconverter showing f8).
You have the best of the lot with 360B. In order to mount or dismount the TC or the PK/A or PK/M adapter, the lens' aperture has to be moved to the widest (f2.8) setting. The TC should show f5.6 as the focal length is doubled, you lose 2 stops of maximum aperture. If the TC shows f8.0 instead of f5.6, it may be caused by improper mounting of the TC to the lens. Once you start mounting the TC or the Adaptall-2 mounts, it should be mostly problem free.
Hope this helps,
