This camera is very easy to operate. I’ve never had the user manual. Let’s start from the front of the camera (please look at the top photo). On the shutter button side of the lens mount (from top), DOF review button, AF switch for selecting between the center circle or bracket area in the viewfinder, and lens release button. On the other side of the lens mount, shutter release cable plug, the center button is for turning on/off of beeper and when the flash is up, you can select flash modes (manual, auto, redeye), the bottom is AF/MF switch. The camera uses the same cable release as SF and PZ series of cameras. If you search under the key word “Pentax SF” on ebay, you’ll find this cable. I put up a wanted ad here and a member was so kind to give me one for free.
On the shutter side of the top panel, there is a shutter time dial, press the center button to turn the dial. The dial below is for selecting metering mode, you don’t need to press the center button. On the other side is EV compensation dial, you can also set ISO of non-DX film by lining up the arrow (up or down) with the – mark and press ML button to change. The bottom dial is for selection of single shot, multiple shot, timer, and bracket +- ½ or +-1 stop. On the back are pano switch and memory lock button. If you want to re-wind film in the middle, press the switch inside the little hole right below the back door latch.That’s all there is to it. Below is a sample photo taken with this camera and F35-70mm lens.
https://www.pentaxforums.com/forums/attachments/pentax-film-slr-discussion/97...ots-winnie.jpg
