01-13-2021, 08:07 PM   #1
Pentax K-3 II GPS Flex Circuit (or dead camera)
I acquired a Pentax K-3 II that had been dropped and appears to have suffered more damage than I originally thought. During the disassembly process, I discovered the flex circuit connecting to the GPS antenna was broken. It looks like the adhesive that originally attached the flex circuit to the top housing let go, allowing increased movement that eventually resulted in a stress fracture.
Without the flex circuit the camera locks up within a few seconds of turning on, and won't turn off without removing the battery (similar symptoms to the initial K-3 II power off problem). If anyone has a flex circuit from a dead camera (or a complete dead camera), please let me know.
01-14-2021, 07:19 PM   #2
ebahle's Avatar
I have a K3 with bad meter, would that fit the bill or are you needing a v2 k3
01-15-2021, 07:36 AM   #3
QuoteOriginally posted by ebahle Quote
Sorry but a K-3 will not work. I specifically need the flex circuit that connects to the GPS antenna and is only used on the K-3 II. The connectors are different at each end, so I cannot use a generic flex jumper . Thank you for reaching out though.
03-09-2021, 01:07 AM   #4
K3 II parts
I have a K-3 II that was dropped and not able to be repaired for less than the cost of a replacement. I used it for several months after it was dropped but it was never the same. But the GPS was working before the camera died completely. I took it partially apart after it was returned by the repair facility bas unrepairable. I left the cover off of the GPS and it is around but not sure where.
If you are interested PM me.
camera, circuit, classifieds, flex, gps, gps flex circuit, ii, ii gps flex, k-3, k-3 ii gps, pentax k-3 ii, sell pentax, wanted
Skylum releases update to Luminar Flex pepperberry farm Digital Processing, Software, and Printing 8 07-16-2019 11:01 AM
For Sale - Sold: Pentax GPS Unit O-GPS1 Hotshoe Mounted Accessory GPS Unit for Pentax Toolmaker Sold Items 3 10-08-2016 05:15 AM
K-1 Flex-tilting / rotating screen -- Strong enough to support camera body! grahame Pentax K-1 & K-1 II 24 02-18-2016 06:14 PM
da 21mm ltd a bit of "give" or flex between the parts house Troubleshooting and Beginner Help 4 05-13-2015 11:06 AM
Pentax O-GPS1 GPS - Faulty k-5 or GPS Unit? KansasHorizons.com Pentax Camera and Field Accessories 6 01-04-2014 02:34 PM
All times are GMT -7. The time now is 10:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
