Veteran Member Join Date: Feb 2007 Location: Ontario |
Here's a little lighting 101 from a cinematographer's perspective.
I have to disagree with this who are suggesting crank the EV or turn up the f-stop. In experience as a cinematographer on a number of films, on set you have to be totally in control your of your lighting, both natural and artificial.
There are four main aspects of lighting that you look at, and adjusting exposure only takes the one into account. Light has quantity, quality and colour/temperature and direction.
Quantity is obviously the intensity, and will influence exposure of your subject, and your subject relative to the your background and environment. Quantity of light obviously affects aperture and shutter speeds, and may limit focal length, depth of field, and so on depending on the conditions. But adjusting how much light you let into your recording device is like clearing a table with a baseball bat...it's indescriminate, and while it solves one problem it creates others.
Quality of light is whether the lighting is harsh and direct, or soft and diffused. Are the rays of light coming in from a single vector, or are they being reflected and refracted to come from many different angles? A mirror reflects light without diffraction, while white objects do the opposit, so as reflectors they will create very different results. If you're worried about the quality of the light (and consequently the shadows) on your subject, diffusing is the way to go. Adjusting EV and shooting RAW will help you to expose your subject properly, but does nothing to affect the quality of the light and the shadows. There is a reason HDR processing often looks unnatural!
The colour temperature / hue most often comes into play with regards to white balance, and when you're mixing natural and artificial light sources. A tricky situation.
Direction, for the most part, speaks for itself. In film, high-key lighting is light that comes from a source that is near the camera and creates a flat, evenly lit subject, but may cast shadows behind said subject. See the on board flash for examples. Low-key lighting, lighting from the sides, creates shadows across a subject which emphasizing features but is often 'uneven' if there is only a single light source. Afternoon sun light from the side us usually less than falttering. Back light, rim lighting, catching lighting, 'kickers'....I could go on and on.
Lets take the example of the fill flash used here. It's a perfect learning example. What we have is warm (temperature) direct (quality), bright (quantity) light coming from the right, slightly above and behind the subject (direction). It's low-key, almost rim lighting at this angle. This light casts a shadow over the subject's face, and down his front and shirt.
In compensation, we have setup a flash gun somewhere to the left at about face level if I am correct. This light is slightly cooler (temperature), direct (quality) bright (quantity) low-key (direction) light source, and so it is casting shadows and picking up features in the opposite direction.
Results:
Quantity: The shot is properly exposed. The background and subject are both exposed properly without losing highlight or shadow detail.
Quality: Since the lighting is direct and non-diffuse, shadows will appear harsh, with defined lines between light and dark areas. The effects of this will be most relevant to the direction of the light.
Temperature: The flash is slightly cooler than this slight afternoon sunshine, and this leads to a pale washed out look relative to the lush greens being exposed by sunlight alone. It's what's called a mixed lighting situation. Our eyes and brains deal with it well, but our cameras don't. The white balance can do so much, but with different colour temperatures you're looking at either making your flash look blue (as here) or if let your set the WB so your flash looks warmer, the sun light becomes much more orange. Either way, it tends to look somewhat unnatural.
Direction: There are a lot of shadows being cast since there are two low-key lights in this situation. As a result we pick up the wrinkles in the shirt, get shadows in the sleeves and under the arms, and dark areas from the flash along the right side his face from the nose. Again, since the light is not very diffused shadows are harsh and very visible.
What's the solution? It depends. Shooting outdoors it tough. You can use a lot of things to help you control the four aspects of lighting. For a small flower, or bug it could be as simple as carrying a piece of parchment or waxed paper, a white tee-shirt, or anything that will diffuse the light. The folding discs are great as diffusers and you can or reflectors. Look at these and think about how they will affect the light...gold reflectors give that warm, diffuse glow at the beach, for example. Remember too in diffusing light you lose quantity so that macro shot may lose some DOF due to a larger aperture. Fill flash has to be controlled like any other light, which is why macro lighting setups are so flexible. Perhaps someone here could point the OP to some macro lighting examples (photos of a setup?).
As the subject gets larger (read: People!) things get more complicated.
Hope this helps.
Cheers,
Damian
