I had an important family birthday event last weekend at a venue not familiar to me. My folks, having seen the photos I took with my new k-x at Christmas, wanted me to “cover” this event. Not knowing what the venue was like, I purchased an external flash a couple of weeks ago as I was afraid I might face some challenging lighting conditions.
Sure enough, thats exactly how it turned out, it was an indoor event on a bright sunny day. A few months ago I had a bad experience in a similar situation (indoors, sunny day) which I tried shooting without a flash and ended up with many poorly exposed, out of focus shots. After that experience I realized I needed a proper flash.
What I did right this time:
1) Bought an external flash
2) Was pretty successful balancing ambient light with flash by using the techniques described on the planetneil site (shoot with camera on manual, flash on ttl, bounce, underexpose by ~2 stops on camera, adjust EV on flash to taste). I got quite a few nice candid shots, and the group shots turned out really well. I would have been toast for the group shots if I hadn’t had a external flash with me as they were in a fairly dark corner of a room than would have made ambient only shooting at the higher f stops needed for group photos impossible.
What I did wrong:
1) Didn’t realize that using a flash disables the shake reduction system.
As a result I set the shutter too slow for some shots and got some blurred shots. Luckily I only lost a dozen or so shots with this, but I’m not going to make that mistake ever again. I should have practiced more with the flash at home before the event to realize this.
2) I forgot to switch from manual to AV priority when I took some shots on the balcony lit by natural light, as a result I way over exposed half a dozen photos.
Luckily I reviewed the images after a few shots and realized my mistake. Note to self, when moving from inside to outside don’t only turn off the external flash, switch the camera mode. I could have adjusted manual settings I guess, but by using Av for outside and “M” for inside I was able to effectively “save” my settings and so switch between them with one quick knob twirl.
Oh yeah, the other thing I learned was that my 17-70 is beginning to disappoint me, yet another batch of photos taken with that lens that are only average at best, my keeper rate with this lens is low. I can’t shoot below f5.6 on this lens if I want a remotely sharp photo, and even then it’s not a patch on my ltd primes.
OTOH my DA40 was great, particularly for the group shots, and I was reminded again just how superb my DA70 is, that lens can’t help but take fantastic portraits. I absolutely love this lens.
Only other thing is that I did have to do quite a bit of lens swapping on the day, something I wouldn’t have had to do as much if I owned a 50-135mm
. I think this will be my next lens for exactly this kind of situation, but I don’t think I’ll ever be able to part with my DA70, have I told you how much I love this lens?
