Originally posted by hangu You have a better idea? If not, don't be a jerk.
I don't see what's wrong with this method, focusing screens are what, $30? I would do it if I needed to consistently crop.
TRY it. I wasn't being a jerk.
If you have not tried it, you cannot possibly know if it works.
My idea? Read the post I put up after you posted your duct tape and baling wire solution. And while you are mulling over the difference in price between your solution and mine, and how that makes yours so much more superior, make sure you consider that he has a business plan and is holding himself out as a professional.
The standards are generally higher, and equipment is crucial. Equipment costs can be written off, depreciated or whatever. Gumming up a camera with electrical tape and adhesive is simply not going to solve the issue; nor is having to change the focus screen every time you want to switch formats. That is of course if the screen even really fits and operates correctly once the tape is put in place. And, uh, how do you insure that you have the guide lines right? Experiment? What about the warranty. Does this void the warranty? So you keep another screen around in case you have to send the camera to Pentax. It's like lying. Too many things to remember.
When you get through with that analysis, switch gears back to probability of success, as well as overall ongoing functionality/adaptability/cleanliness of the two solutions.
Money is not the object. Which solution appears better? Sheesh.
woof!
