Originally posted by ronald_durst (snip) The field will be lit but not enough to do without flash since its at night. Does anyone have any experience with this and what are your techniques? Also what kind of equipment do you recommend?
Flash is seldom powerful enough to cover anything beyond midway to the other side of the field while standing on the sidelines. This might work if your friend covers one side of the field while you cover the other. But if you're expected to cover the game yourself, I'd suggest forgetting about flash.
Instead, practice capturing those dramatic moments when the action slows - the quarterback moving back as the ball is snapped, the quarterback freezing to throw the ball, the receiver slowing down to catch the ball, the two players nearly stopping during a tackle, the two players hitting the ground following a tackle, etc.
For your nighttime games, use the fastest ISO setting available on your camera (to allow the fastest shutter speeds) and be prepared to deal with image noise afterwards. Software is available to remove such noise. Buy something now and learn how to use it to the best effect.
Pay careful attention to exposure metering. The field lights are going to throw some very harsh shadows. In the huddle, for example, the faces of the players leaning downward away from the lights are going to be very dark. If you want an image of this, be prepared to add some exposure compensation (remembering to turn it off afterwards for subsequent shots - forgetting this is a common mistake).
As for the lens, I'd stick to a standard to short long telephoto (200 or 300mm max). Since you friend's sports paper is not likely going to use huge images, you can easily crop images downward to get tighter shots of the action. At the same time, a shorter telephoto would allow faster apertures, hence faster shutter speeds.
Well, that's about it (the basics). Practice is the most important thing. Study your images afterwards to discover what needs to be done to correct any problems. That could be changes in your equipment or just changes in your shooting habits. Good luck.
stewart
