08-03-2010, 01:16 PM   #1
ISO for daylight shooting wide open F1.4
I just got my new SMC-A 1.4 and cant wait to test it!
What ISO-speed should i use to be able to shoot wide open in daylight? Is this possible? Filters?
Cheers
08-03-2010, 01:23 PM   #2
alohadave's Avatar
Try it out. You can shoot at whatever ISO you want.
Lower is generally better for daytime, especially if you are going to be shooting near f/1.4.
08-03-2010, 02:38 PM   #3
Lowell Goudge's Avatar
you might find wide open there is too much light without a ND filter or polarizer.
go out and play a little, then think about filters if there is too much light.
08-03-2010, 02:45 PM   #4
KxBlaze's Avatar
Definitely as low as possible (100 maybe). But even then depending how much sun light there is you might have to shoot at a very fast shutter speed.
08-03-2010, 05:39 PM   #5
Wheatfield's Avatar
Lowest ISO you can.
This is a pretty good rule of thumb actually.
Shoot the lowest ISO you can use to get what you want in any situation.
08-03-2010, 07:13 PM   #6
I think shooting wide open you will definitely need to shoot at lowest ISO possible, even still without a ND filter you will probably get some overexposed photos unless you can shoot at over 1/4000th sec.
08-03-2010, 08:22 PM   #7
100.
08-03-2010, 08:47 PM   #8
ManhattanProject's Avatar
QuoteOriginally posted by JeffJS Quote
100.
Yea... I always use 100 outside from dawn to dusk.
But to the OP, every situation varies. This is really a stupid question, if there's such a thing.
08-04-2010, 05:53 AM   #9
Ira
QuoteOriginally posted by ManhattanProject Quote
I'm the exact same way, unless it gets real overcast and I have to go to 200. But people have posted here that it's not a true 100. And remember that you have to have Expanded Sensitivity On and Highlight Correction Off to have 100 available.
BTW:
Does the OP realize that on the K-x (and I assume other Pentax DSLRs), your range of available ISOs is linked to your preferences for Ev (exposure compensation)? In other words, if you have your Ev settings at full stops, you will only be able to select ISO 100, 200, 400, etc. But if you have it set to 1/3rd of a stop, you'll have available like 100, 135, 175, etc.
08-04-2010, 06:15 AM   #10
I dont agree. I want to know which ISO-speed gives me opportunity to use F1.4 in full sun with my camera shutter speed ranging from 4s-1/2000s.
Is there film under ISO100 (i.e. 32 or 64) on the market?
Maybe i have to use a ND filter though cause of the fast shutter speed required.
08-04-2010, 06:53 AM   #11
Wheatfield's Avatar
QuoteOriginally posted by pyra_ohms Quote
Why don't you go out and take some pictures, find out what you need to do what you want and then work towards acquiring it?
If you want to use an f/1.4 aperture in full sun with a 4 second exposure, I suspect you are in for some difficulty, but I'll leave you to figure out why on your own, as the learning experience will be good for you.
08-04-2010, 06:56 AM   #12
you should have reminded everybody her eyou shoot with film camera (also it obvious in your gear list, most people here use DSLR).
Maybe 64 exists. IF not, depending the fastest speed of your camera shutter, you may have to put a ND filter.
08-04-2010, 07:32 AM   #13
Ira
Oooops:
Film.
08-04-2010, 08:32 AM   #14
Film changes everything.
08-04-2010, 11:09 AM   #15
Oooops:
Film.
Being too lazy to unzip a camera bag and walk outside with a 1.4 on one of my film bodies, I looked at my Sekonic L398. At the meter's normal indication for bright sunlight, at ISO 100 an aperture of 1.4 would require a shutter speed of 1/16000 (Off the scale for the meter, but I did a bit of mental arithmetic.)
Testing indoors or waiting for dimmer natural light would be cheaper and simpler than using an ND filter, and would probably give a more accurate indication of lens performance. Sticking a filter on a lens at 1.4 is probably not a good thing in terms of sharpness or contrast.
camera, daylight, photography
Nature Some wide open Tulips JeffJS Post Your Photos! 6 04-18-2010 07:37 AM
Colored cameras, daylight shooting, and harsh shadows Eruditass Pentax DSLR Discussion 10 09-26-2009 07:06 AM
77/1.8 wide open... igor Post Your Photos! 14 08-17-2009 05:36 AM
Which 50/1.4 is best wide open? Big I Pentax SLR Lens Discussion 5 08-05-2008 09:23 AM
DA 18-55 wide open Ash Pentax SLR Lens Discussion 16 01-03-2008 08:30 PM
All times are GMT -7. The time now is 10:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
