Originally posted by an49 maybe I'm wrong but if you choose that shutter speed,
the shutter will open and close before the flash even thinks about flashing.
As far as I know the durance of the Flash is much shorter (about 1/2000 - 1/5000 depending on the flash).
The time 1/200 (1/180 on my K100) is the shortest time that the camera is able to interact with the flash.
You may chose a shutter time like 1/60 or longer the durance of the flash will
sharpen the object.
greets an49
I did not make myself clear enough. Sorry about that.
The question is
not how to make flash photos of a fast moving object.
It is not about taking flash photos at all in fact.
It is about photographing fast moving objects at close range with no flash.
It is considering that a focal plane shutter (as in our DSLR's) can only be
completely open at relative long shutter speeds.
You can determine that minumum duration by looking at the highest flash sync speed.
Have a look at the video in this post:
https://www.pentaxforums.com/forums/pentax-dslr-discussion/111375-say-what-k1...es-second.html
You can see that the shutter takes about 1 second in that movie to go down.
At 5000 frames a second, slowed down to 25 frames a second that is 1/200 sec = 0.05 sec. That matches the maximum flash sync speed.
So, the maximum flash sync speed of a camera can tell you the time the camera shutter needs to traverse down.
Looking at the video clip again, you will see that the shutter is open by a small area only! (1/4000 sec for all pixels of the entire photo)
For 1/4000 sec in a 1/200 sec cycle time, the opening should be 1/20 of the entire plane.
This means that during the shutter cycle time (0.05 sec) a fast object will still move relative to the camera's position.
While the opening in the plane moves down, the object will move to the right.
When the object moves so fast that it will traverse from left to right in the same time as the curtain travels from up to down, you must see a very morphed picture of the object.
I'm wondering if anybody has captured a picture like that.
The object should be looking stretched from the left top to the right bottom.
I've tried to make a picture a 90mm lens, moving fast past some vertical blinds, without any success.
What is wrong with my reasoning?
- Bert
