Originally posted by jaieger Hmm, okay. And also, what's the difference between the 3? Does doing one yield a higher magnification than the other or something?
The various methods allow for a wide range of magnifications depending on the amount of physical or "optical" extension and the lens focal length available. Unless you're accustomed to "setting up" your compositions based on field of view, depth of field and lens perspective there's little to choose between the methods - often it just depends on what you have available at the time.
As mentioned earlier, reversing a lens is specifically useful when a flat field of focus is necessary in copy work. Consider that a 'normal' lens is focusing on a very close, flat 'sensor' but the in-focus point(s) of a distant scene are on a curved plane at a fixed radius from the lens. Keeping the center and the edges both in focus with a shallow DOF at close range becomes an issue and reversing helps. It's cheap and easy to reverse a lens but it doesn't offer the versatility of extension rings (or bellows). You can easily explore this effect by simply holding a reversed lens to the camera body.
Stacked lenses also limit versatility and become cumbersome and 'nose-heavy' in use. Best used when extreme close-ups are needed with fixed set-ups IME. Again, just hold the second lens in front of the mounted lens to try it. I've made photos in the field by taping lenses together with electrician's tape -- keep it simple.
One option you might explore is the Vivitar or Panagor Variable Macro tele-extenders. Acting much like a "zoom" extension ring, both will give satisfactory results up to about 1:1 ratio with 35-70mm lenses and can be had with auto-exposure functionality. (Pick up a cheap PK-mount variable macro tube and a cheap M42 Sears 50/F2 lens on eBay and epoxy them together (concentrically of course, the M42 fits inside the K-mount) and go have fun.
The Raynox close-up lenses mentioned by Marc (and other multi-element diopter lenses) are also a versatile and economical solutions and easy to keep at hand in the camera bag.
You might find "Close-ups in Nature" by John Shaw and/or "Understanding Close-up Photography" by Bryan Peterson very helpful books. Reviews/previews available on Amazon. Search the net for "macro" or "close-up" plus any of the equipment terms and the articles section in this forum as well.
H2
