Originally posted by Tommot1965 when doing HDR in post processing..do you capture three images at different exposure setting. then merge the three ?
if so have far past the cameras light readings do you go for the two other images..one stop each way ?
just interested
I haven't got a universal pinned down, but generally, I bracket 1.3 stop exposures and then use exposure comp to bias. I use aperture preferred auto for this, the camera adjusts the shutter speed, which is kinda required so that the depth of field doesn't change from shot to shot.
If you use auto bracket, you can set either 3 or 5 exposures. Three is plenty for HDR processing, five gives more options during post.
I find this method to be faster than manual exposure control most of the time, though when it fails, I move over to manual and turn off auto bracketing.
