Originally posted by spystyle How do you get them to fit ?
FORCE-FIT! I'm no Nikonian so I may have the terminology wrong, but here goes: I have encountered 3 types of Nikon lens bases. There are AF lenses, which I can't force-fit onto my K20D mount (but I only tried one). Among manuals, there are AI lenses, which have what I call "nub and arc" protrusions from the aperture ring. Also manual, there are non-AI lenses, which have a continuous skirt around the aperture ring.
Non-AI lenses can be simply force-fit onto my K20D's mount. I might get about 8mm of grip of the bayonet lugs. I feel very unsafe doing this with a big heavy lens. Also, the aperture ring may press against the camera body, making it hard to change f-stops. I alleviate that by CAREFULLY unscrewing the lens base, then sticking wee little bits of tape under the base to push it out maybe 0.4mm.
With AI lenses, I use a Dremel metal-cutting blade to chop off the"nub and arc", and make sure the bottom of the aperture ring is smooth. The lens then force-fits to about the same degree as with non-AI, but the aperture ring now turns freely. And the lens' metal base safely shorts the PK mount signal pins, which lets me use Catch-In-Focus.
No, force-fitting does not produce a lock-tight fit. One of these days, I may dremel a small slot into the lens base for the PK mount locking pin to fit into. THEN it will be secure! But I haven't lost any yet, and I've modded four lenses, with more awaiting surgery. Note that this surgery probably reduces a lens's resale value a bit, so you probably won't want to cut a costly lens.
