[This is not really a camera specific issue, so I thought I'd post this here, rather than in DSLR Discussion].
I've long been puzzled by this. Maybe someone can explain why this is so.
I know in theory a 12MP camera (like the K-x) should deliver less resolution than a 18MP camera (like Canon's 550D/60D/7D or similar). But in charts like the ones below this isn't the case, and it is a consistent issue.
A 12MP camera like the K-x can even be shown to deliver consistently HIGHER resolution than the 60D. For example in the charts below one can see that from
ALL ISO's above ISO 400 the resolution of the K-x exceeds that achieved by the 60D (at the RAW centre). Only in the JPG measurements does the 18MP camera consistently beat the 12MP camera, but even in JPEG the resolution difference is sometimes only marginal.
K-x chart sourced from Photoreview.com.au
camera review for the K-x
60D chart sourced from Photoreview.com.au
camera review for the Canon 60D.
You can also see similar results to the 60D from the Photoreview
Canon 7D camera review.
This isn't just a measurement issue with Photoreview.com.au.
DPreview notes the same in their 550D review: "The difference between the raw output of the EOS 550D and the Pentax K-x is ... so subtle as to be almost irrelevant to normal photography at print sizes smaller than A3."
Only when you move into
Canon 5D2 (22MP) or
Nikon D3x (24MP) territory do you see consistent high resolution being achieved in the Photoreview.com.au test charts.
This issue of interest to me. I've recently been doing a lot of birding and being able to crop heavily into shots has always been one of the attractions in the back of my mind about (affordable) higher megapixel cameras like the 550D and 60D, not to mention new cameras like the K-5.
But according to what I am seeing in these charts and tests, if I stick to RAW and use a good RAW processor (eg LR3) - which is what I am doing now - I won't gain any practical, usable resolution improvement from moving from the K-x up to a higher resolution camera like the 60D or K-5.
Not until I move into big money camera territory like the D3x (which is not going to happen) will I see a real RAW resolution advantage (ie > than 25%) above the K-x.
tl; dr: Why doesn't 18MP deliver SIGNIFICANTLY more resolution than 12MP?
