Originally posted by milesy HI All
any ideas on how i can estimate the amount of time needed for a long exposure.what i am trying to do is recreate some of those photos taken at night that look like they are during the day (im sure you know what i mean)
Like this?
Pentax K20D
Cosina MF 20/3.8 Quote: obviously the in camera metering is pretty useless while its dark, so how can i estimate the time needed (by the way using k-7)
Nass has hit the nail on the head. Trial and error will do the trick, but as each shot can take several minutes it is an incredible waste of time and battery to start your guesswork at your shooting ISO. Crank it way up. Also open up your aperture for the guesswork phase. At this point you don't care what the DOF is or whether the shot is in focus or how grainy it comes out. All you want to do is get your exposure time figured out. Take a short shot, review on the rear screen, take a look at the histogram, and try to make a guess how many stops your need to adjust. Usually a couple or three (relatively) short shots are enough to do the trick. Then it is just a matter of doing math in your head to compensate for adjustments to arrive at your shooting ISO and aperture. Just remember that each stop up or down results in a doubling or halving of the shutter speed.
For example, if your test shots show at ISO1600 you need 10 seconds, then 800 would be 20, 400 would be 40, 200 would be 80, and 100 would be 160. If you tested at f4 but want to shoot at f16, then that 160 secs at f4 goes to 320 at f5.6, 640 at f8, 1280 at f11, and 2560 seconds at f16. Of course, it gets a bit ridiculous doing that sort of math, so at some point you may want to do some rounding in your head and switch off to minutes and fractions of minutes. 640 seconds at f8....may as well call it 11 minutes....f11 is 22 minutes, f16 is 44 minutes.
As you can see, the further you go along those lines, the greater the amount of time between each stop of exposure. And there is a correspondingly decreasing need for neat precision in timing your shots. Cutting off a minute or two too soon or too late is not all that great a difference in exposure and isn't worth worrying about if you're talking about something like a 44 minute exposure as in the example above.
Naturally, you will need to have with you some sort of locking cable release (or locking remote) for doing exposures over 30 seconds. It helps tremendously to have a watch with an alarm function. I use the timer on my iPhone. I've had some luck doing night shots up to about 10 minutes long just by counting off the seconds out loud when I forgot to bring something to time it with.
It also helps to have something to
do while you're standing around waiting for the time to go by. Or to at least be the type who can appreciate being able to stand there and enjoy the quiet and solitude without a damned thing to do.
