Originally posted by Impartial
With Olympus rumoured to have released their last true DSLR, Samsung and Panasonic already out of the market (moved to EVIL), and Sony also rumoured to leave the SLR market for its SLTs, will we be down to three manufacturers (Canon, Nikon, Pentax) of actual DSLRs by 2015? What do you think?
Let's face it, the 4/3 market was doomed to fail due to the extreme cost of a wide angle lens, that still respected a large enough system regestry distance to swing a mirror.
They will do much better in the EVIL domain because they can do a lot more with the lens using the reduced regestry distance.
the real issue is that for many applications, the low level performance of an EVIL camera for viewing and focusing si pretty bad, I know, I also have an EVF camera, and also just look at the low light image in live view on a K7
The optical view finder and big sensor of a DSLR will still take a good share ov the market. and where I see EVIL cameras or EVF cameras wit big sensors taking over is the travel camera market.
The hell with an SRL if you can have an ASP-C camera with a 16 - 75mm lens at F2.8. that would be equivelent to 24 to about 110mm and would cover most even hard core travel that except for tele uses you would not need anything else. Couple that to a well designed 0.5x front converter matched to the lens, and distortion correction software and you have it all.
