Originally posted by Ira What are you thanking him for?
Olan Mills was a guy's actual name:
Supporting my original suggestion to use your actual name.
The OP specifically stated he wanted suggestions beyond his own name. I started my response with the qualification that use of one's own name is probably OK in photography. I then proceeded to point out why one MIGHT want to consider not using one's name. What was the harm there? Again, given that the OP had SPECIFICALLY requested suggestions OTHER than his own name.
I am sorry you took that personally. On the point of Olan Mills being someone's name, thanks for the kind and polite correction. I do not however have any reason to retract or even modify my original point. There is nothing further to be said about that. It is common sense and I stand by it.
You are trying to hijacking this thread as a platform to prove yourself "right" YET AGAIN. I doubt it is appreciated. This is not about YOU. Sit DOWN.
PrivateRyan, I am sorry. Truly sorry. I do have some suggestions. I'll take those to PM now.
woof!
