in readig the article one could draw another conclusion also, specifically that the canon F1.2 lens and the nikon F1.4 lens are not really F1.2 and F1.4
While there has been discussion in the past about old technology lenses and having light hit the sensor at oblique angles, this was most at issue at the corners and caused vignetting.
Also, the discussion here is about the problem of CMOS sensors and the deep well design associated with CMOS, and not CCD sensors. Although I have not checked every model of nikon camera in his chart, I am quite certain most of the cameras are CCD and not CMOS therefore the argument may not hold true.
A long time ago there was discussion about camera makers cheating on ISO settings, and not having the ISO settings set as indicated, in order to give brighter and brighter images. I believe canon was at the root of this also, in terms of being the worst offender.
It would be interesting here to see the performance of the systems discussed AT ALL APERTUTES, what is presented is a single datapoint, that only really shows IMO exposure error of lenses wide open, and this is NOT the best judge of the lenses or the sensors/systems.
With respect to the movie industry and T-Stops, the reason they moved to T-stops was because the medium had such a small exposure lattitude that they had no other option if the exposure was to be spot on. It is not because all lenses are so far off the mark, it is because when making a movie on film, with minimal lattitude in the first place, the 1/3 stop made a difference, an big difference.
As an aside, while I am skeptical about camera makers fooling substantially with the ISO ratings, I have no reservations AT ALL about camera makers fooling with metering and the issues associated perhaps with bright focusing screens and fast lenses. Just look at how the K10D meters with fast manual lenses, or lenses taken out of the A mode, yet they meter perfectly with the same lens in the A position. Clearly the camera has the metering inaccuracy "calibrated out" for known maximum apertures.
