Originally posted by Gary G I want to get more involved in macro photography. Not close-up work, but true macro. I am in the market for a dedicated macro lens, but without prior macro shooting experience I am not sure what I should be looking for. I realize that macro lenses can be very expensive, and you certainly get what you pay for, but is there a middle ground somewhere for a macro beginner like me that will not cost a small fortune?
I want the ability to shoot 1:1 or reasonably close. Is there a bargain range of macro lenses to choose from that will allow me to take a few steps into this field to get a feel for it and to see if it is something I want to continue to pursue? The used market is fine, but as I said I am not sure what I should be looking for. I can always do a lens upgrade later once I become comfortable with shooting in macro.
Any advice is appreciated. I currently own a Pentax K-x, which is a great camera for what I am currently using it for, but I want to expand my photography interests into the macro realms.
from my experience there are a couple of things to look for, and this can be relitively cheap to get started.
- My preference is normally for longer focal lengths, because this allows greater working distance, which also facilitates easy lighting.
- Go for manual focus, because AF will never focus on what you want.
- get extension tubes, for your lens,
- look at getting a macro bellows and an enlarger lens as an alternate to a macro lens.
you should be able to get a reasonable setup for about $100-$150
If you go the macro lens route, get a macro focusing rail as well, and if you go the bellows route make sure the bellows has a slide on the tripod mount (this does the same function as a focusing rail) because it is important to be able to move the complete camera and lens back and fourth to get approximate focus at the desired magnification.
I have 3 macro setups, a takumar 50mmF4 with extension tubes, an SMC-M 100F4 with extension tubes, and a bellows with a 135mm enlarging lens. The bellows has a T-mount front, so I can using an M42-tmount adaptor mount any takumar lens to the front.
with the bellows I can get very high magnifications using my 50mm lens. but you begin to lose working distancve rapidly below 1:1. 1:1 happens at 100mm working distance for a 50mm lens, infinite magnification at 50mm working distance.
