Originally posted by Syb ... kind of technique was used for
this photo?
Can it be taken into the mountains in a bag? ... guess not...
Of course you can take one portable, Syb.
There are several portable
scanning electron microscopes on the market, including the
Hitachi TM-1000. This unit measures just slightly taller and wider than a standard twenty-inch television, weighs roughly a hundred-fifty pounds, and will only set you back about $58,000 (US). A bit expensive for a field device perhaps, but the TM-1000 offers imaging up to 10,000X, or about 1,000 times past the point of the best high-end optical microscopes.
And I've personally seen it used in the field. Once worked as a sales rep for Hitachi. There is a padded bag available, but a foam-filled metal case with strong handles is a wiser choice. It is also a good idea to keep it out of the sun since images start to degrade sharply above 75°F. Finally, there is an interface available (about $6,500 IIRC) that will allow it offload images directly to a digital camera, including the Pentax (t-mount).
stewart
