Thank you for that! Great points to consider, and I did consider as I read them. So far though I"m not too put off.
As I hinted at, I'm not excessively exacting on the technical side. What I'm aiming for is a reasonable, for my tastes, digitization of my old slides.
So...
Quote: 1) unless you have bought millions of carriers, it will take almost as much time to load and unload the slides into the carrier for each box,
All the slides are already organized into carriers (not millions!!!!)
Quote: 2) this only does slides, not negatives, I shot both. May not be an issue for you though.
I just want to copy the slides. A lot of this, (more than half) are slides from my father's photography. The negatives are long lost.
Quote: 3) you need to consider that you may have shot, over the life of your film career, more photos than the estimated life of a DSLR shutter. consider replacing the shutter or buying a new camera as part of the potential cost here.
I anticipate doing this with a mid level Samsung compact digital. Superior imaging by far compared to any of the affordable "slide scanners" available to me and I"m confident that the quality will meet my needs judging by the work I've done with it so far.
Quote: 4) You will need to have something hold the slides in place, so that fixed focus will work, or have an auto focus period for your lens to refocus each time a slide drops in place.
This is where the autofocus feature should come in real handy. The mechanisms in these slide projectors must be iffy at best since, as I recall, when viewing slides the focus is often adjusted while going from slide to slide to get a sharp image on the screen. Auto focusing on the compact digitals is, I'm pretty sure, going to be able to compensate pretty adequately on the image of an illuminated slide.
Quote: 5) White balance, you will need to have something set here to correct for it, I cant see you post processing all your shots, I would assume you are going to do JPEG?
Ok, now you've succeded in worrying me. But a balance setting fixed in the digital camera is, once it's set, at the very least, not going to be any better or worse than what is being witnessed on a projector screen at any given moment. I'm happy with that.
Quote: 6) Dust is your enemy. I spent quite some time making sure that each time I loaded the carrier the slides (or negatives) were really clean. you will have years of $#!? potentially on your slides. the resulting scans won't be worth anything if they were done with dirty slides.
Again.... as long as I've archived the best that I might expect from viewing these images on a screen, displayed through a slide projector, with sufficient precaution and preparation to deal with what dust can be dealt with, I'm a happy man.
