12-25-2010, 04:34 AM   #16
Maybe you can lift the top of the Grand to avoid any problem. Your comments are noted but you may be respected for asking to preview and test sometime before the actual day of your assignment. Good results are normally the product of hard work not laziness. A possible problem of bouncing the light is that the colour of whatever the light is bounced from will likely affect your subject(s). Like the green cast so frequently seen in portraits where the subject is under a tree for example. So, IMO, you must view the conditions and do some testing before the appointed day. Good luck.
12-28-2010, 06:17 AM   #17
Start with the most difficult part of your photo - the black grand piano. Your room should be dark or very dimly lit. Gradually add your lighting watching to see how it reflects from the piano. You can add to your equipment by making large rectangles of different widths from 3/4" PVC pipe, then stretching and taping white or black paper on them. Bouncing light off the white will give you controlled large areas of reflection; the black will help to reduce light where not wanted. Avoid direct lighting. Once you have composed the piano, add the young lady and concentrate on the light falling on her. For a senior portrait, the piano should not be dominant, but play a supporting role.
12-28-2010, 09:52 AM   #18
mel
mel's Avatar
Well it's over and the piano kicked my butt. Basically it was in a repurposed dining room, windows with white miniblinds on two walls, wainscoting on the lower walls, and a chandelier (casual in style). I could only get about 2-3 feet away from it on 3 sides. I think we got some that she'll be happy with but ideally, it would be nice if the piano was on a stage with movable stage curtains all around and absolute control of the lighting. Alas, it wasn't to be. It WAS nice, however, to be serenaded while trying to work all of this out. She does play beautifully.
That was just the piano session. We're going to have another couple sessions. She's also the drum major for her school's marching band so we're going to do a little more in-studio with her uniform and some outdoors.
camera, photography, piano
What Kinds of Lighting Accessories are Needed Pt.2 benjikan Photographic Technique 3 01-03-2010 08:41 PM
Shooting Food - Lighting Tips? potatolicious Photographic Technique 8 12-08-2009 02:39 PM
need tips mounting, lighting and where on earth can i get 4x7 prints? messthetics Digital Processing, Software, and Printing 12 10-20-2009 09:47 PM
Tips needed for cropping dgsullivan Post Your Photos! 5 05-09-2008 02:19 AM
Using the 40/2.8 lens for landscape/trekking photography. Tips and tricks needed. lastdodobird Pentax SLR Lens Discussion 20 03-03-2008 10:12 AM
All times are GMT -7. The time now is 07:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
