Originally posted by Lowell Goudge Bert
I don't think you have flair but actually the sun casting "rays" on humid air where it pokes through the clouds. Flair will be manifested by narrow and symetrical lines.
DIstortion of th esun is probably gross over-exposure
Lowell,
Thanks for your response.
I've always understood that the source of the ray shape flares is reflection of the edges of the diafragma inside the lens. And so you can tell the number of leaves of your the diaframa by counting the number of flares. Following that reasoning a round shaped diafragma will create a equal flare. Not seperate beams.
So I thought that the flare kind of light evenly distributed in the +Ev shots comes from a round shaped diafragma. Am I wrong here? I'm not the expert of this.
Anyone?
Now the sun's shape. Adding +1.5 Ev significantly distorts the sun's shape in ways not expected in the 0 Ev picture. Where does that come from?
Evidently the +1.5 Ev is the trigger of something happening. What is that? The jpg algorithm? Anything else? What does adding +1.5 Ev actually do in your camera? It does not change ISO, or exposure time, or diafragma. At least not according to the EXIF data. It does make the picture lighter however. Is increasing the amplification of the sensor analog signal? (always thought that was done by increasing ISO value), is adding some sort of post processing to your picture? Anyone knows? I'm just curious.
Unfortunatly I did not shoot these pictures in RAW+ mode to see the difference...
I sure would like to understand what actually happens when you are changing the Ev value.
Anyone please?
- Bert
