Originally posted by enoeske If you want it to work reliably, a cord is your best bet. Wireless via the pop-up flash as master will be unreliable in a environment with flashing lights (such as a nightclub). And I don't know of any radio triggers that support pentax P-ttl. So, its pretty much just the cord.
well that's sad.
but I have comeup with the solution.
for slow shutters like 1/4 to 1/10 of a second I will use the flash mounted on camera with rear curtain sync feature,
While with radio triggers, I'll use shutter speeds 1/15 to 1/30 sec. and a bit higher ISO so the light will be different, even though there won't be much other effects.
