Originally posted by BigDave Only if the viewfinder is an electronic display (e.g., LCD). Otherwise it is an optical display and the light reflected from the viewing mirror up to the viewfinder IS reflecting the actual light from the scene/sun. However, depending on the optical system design, it may or may not reflect the UV energy.
Regards,
No, this is also the case with an SLR with optical viewfinder. (it is one of the foundations of the SLR system).
If you remove the lens from your K-7 and look up into the top of the camera through the lens mount, you can see the focusing screen. This is a matte screen, you cannot see through it. The lens projects an image of the outside world onto this screen, just like it will do on the sensor when you take a picture and the mirror is moved up. What you see when you look through the viewfinder is the image that is projected on this matte screen.
You can try this for yourself quite easily: (and fun
Take a pair of binoculars. This will be the equivalent of the slr lens assembly. (it probably will be uv coated the same as your lenses are)
Dont look through them!
Point them at the sun. (did I mention not to look through them?)
hold a piece of paper behind the eyepiece so you get a nice sharp sun-dot on the paper. This is your matte focusscreen.
Now if the sun is strong enough and your focus is correct, you can even see the paper charring/burning. This is what would happen if you place your eyes directly in line with the lens, you would be blinded.
However it is quite safe to look at the dot that is projected on the paper, it might be bright but it is by far not intense enough to damage your eye, all heat is lost into the focusscreen/piece of paper.
