Originally posted by Lowell Goudge Time for optics 101.
The focal length of a lens is defined as a function of how far from the focusing plane the lens (simple lens actually) for an object at infinity.
F stop is the ratio (again for a simple lens) if diameter over focal length. (remember focal length is at infinity)
Any lens, when focusing closer than infinity moves out slightly. and the image projected gets larger . The "light loss" is not actually loss, but the fact that the same image is spread over a larger area.
ALL lenses actually get slightly slower as they focus in from infinity due to this same feature. The reason it is not a real problem is that from infinity to minimum focus generally is less than 1-2 mm or much less than 1 stop.
Also macro lenses are designed to be flat field lenses, used for making everything on a plane parallel to the sensor/film in focus.
Just to elaborate a little bit:
Focal length is the distance of the optical center of the lens to the focal plane at infinite focus. As you said, for a simple lens (single element) it is simply the distance of the center of the lens to the focal plane.
The "f-stop" is the ratio of the
size of the opening at the optical center of the lens to the focal length. A 50mm lens with a 50mm opening is f/1 or f/1:1. A 50mm lens with a 25mm opening is f/2 or f/1:2. Again, for a simple single element without an aperture mechanism is it simply the diameter of the element.
A lens can focus by moving closer or farther from the focal plane. Modern lenses with multiple elements may focus by internally moving elements between the front and real elements, but this has the optical effect of moving the entire lens.
Close focusing does cause actual light loss as the lens is moved farther from the focal plane. However, the aperture and therefore the f-stop does not change. The effective f-stop in terms of light loss may be the loss of one or two stops, but the actual f-stop and the associated depth of field associated with the f-stop does not change.
Macro lenses are often measured by the "life size" size of the image: a ratio of 1:1 when the object in real life is the same size as the image size on the film or sensor. To achieve life size, a lens must be extended to the same distance as its focal length. A 50mm lens produces a life size image when it is moved an additional 50mm from the focal plane (and the subject is moved sufficiently close to the front of the lens). Think about that: it really makes a lot of sense given how a lens functions.
Lens extension may be from extension tubes, a bellows, a special "macro" lens with a long focusing helicoid, etc. The light loss is the same regardless of the method of extension.
Close up accessory lenses that you screw on the filter threads are just like a magnifying glass and can increase magnification without the light loss of extension. But the optical quality is usually poorer than a macro lens.
A macro lens is a lens specially designed for high magnification. It usually allows 1:1 without additional devices, is designed for excellent image quality at close focus. It is usually, but not always, designed for a flat field. It usually, but not always, provides better image quality than a regular lens with extension tubes or a bellows.
