Originally posted by NicoleAu Hi Twitch, I am buying a flash on Saturday. Yes I know I have a lot of gaps in my equipment, as has the other tog. When I find out what is happening I will see what can be done then. I don't plan on shooting it alone, it would be way too much for me to handle. Ideally I would like someone with experience to be the main, and me be the second.
I don't know if I have the right personality for it, but I seem to be going ok so far. I have done a shoot with a couple I didn't know at the time and I got some nice shots. Good for the stage I am at anyhow, I think. I am well aware that I have loads to learn and have offered to be a free assistant to some photographers so I can learn more. I have only come into photography over the last 8 months and I'm discovering a passion for it, like I've never felt for anything before. I hope to become the best photographer I can be
The more I use flash the more I realise I should use flash more. I've been mainly using it inside but recently I've been using it for fill and boy is it great, no more dark eye sockets
Yeah it makes you look a bit like a tosser having this honking great flash on top of your camera, but the results are so much better.
Hopefully the flash you are buying is p-TTL capable? p-TTL makes things so so much easier, and without pTTL there is no HSS which is a god send for fill flash so you can go above 1/180 outdoors which is essential IMHO.
Your portfolio is great, but you need to fire that photographer who took your photo
Good luck
