Originally posted by Class A The idea is that you can keep shooting without ever running into buffer limits.
In the low speed continuous mode you should be able to keep firing until the card is full.
That's a very good answer and one I had not thought of.
However it begs the question, does the low speed continuous speed increase with the increased buffer size that can come with firmware updates?
In my logic it should be more dependant on the memory card speed (less dependant on buffer size the larger the cards you use). So the question should really be, does low speed continuous adjust it's speed to the card you are using?
If it doesn't, well we're back at square one with me not really seeing the point. One card may be too slow and prohibit you from shooting it full while another might cope with much more than the speed at which it shoots.
If it does however! Wow, that would be one smart camera!
PS. Sorry for the off topic stuff, not trying to hijack the thread.
