02-23-2011, 05:25 PM   #1
hagiri_11's Avatar
Shooting the sun directly..
Would like to ask, is shooting the sun directly bad for the camera?
If it is, are there any steps that need to be taken first?
Just exploring the possibility of taking a picture of the sun using a telephoto, and see what comes out.
02-23-2011, 05:49 PM   #2
SpecialK's Avatar
I would be more worried about your eye rather than the camera. Sunrise/sunsets are no problem, but noon-day sun would be a problem. But then...why? It's a yellow sphere.
02-23-2011, 05:59 PM   #3
hagiri_11's Avatar
How about using the live view?
I'm just exploring the possibility, just to see what happens and what I can see.
02-23-2011, 06:00 PM   #4
You need to be VERY careful. If you are using a telescope it will be concentrating the sun's rays on your sensor, and we all know what happens when we use a magnifing glass in the sun's rays on a piece of paper. It burns.
I'd be very worried about burning the sensor if you set a shutter speed which is too long.
I'd check websites for astro photography to see what they say.
Regards
Chris Stone
02-24-2011, 11:49 AM   #5
Voytech's Avatar
Live View will expose the sensor to concentrated sun's rays and may cause damage. Same goes for your eyes when looking through the viewfinder. I'm now pretty sure I burned my retina a while back while taking a shot of the sunset with a 400mm lens.
02-24-2011, 12:15 PM   #6
pixelsaurus's Avatar
QuoteOriginally posted by Voytech Quote
If this is true, you will have a permanent dark spot within your field of vision.
Shooting the sun does require care. I would, at the bare minimum, make sure the lens is fully stopped down. Alternatively you can use a solar filter. Thousand Oaks Optical - solar filters, solar eclipse viewers, H-Alpha filters, nebular filters, dew heaters, minus violet
These usually consist of glass or mylar which has an aluminium coating on at least 1 surface. The idea is the reflect the heat before it enters the optical system. In my earlys of astrophotography, I managed to burn a hole in the cloth on a Practika Nova B focal plane shutter. A repair was done using a piece of cloth sticking plaster and a black sharpie.
02-24-2011, 12:19 PM   #7
Voytech's Avatar
Yes. I have the Dark spot. Luckily it's on the border of my peripheral vision.
02-24-2011, 12:37 PM   #9
cadmus's Avatar
Welding masks have replacement glass filters. These used to cost <$3 to replace. I recall using them to observe solar eclipses with no (or minimal) damage to my eye. But this will ruin the color of the sun. (normally turning it green). But you could use it between you and the camera if not between the camera and the sun.
I wonder how homogeneous the surface (photosphere) is, if by using several hardcore filters of different color (freq) could you reassemble the sun surface images with some 'narrow band filter techniques' like you always see on Hubble telescope images. Would you see much texture/sunspots/
camera, photography, sun
Shooting into the sun without going blind Kornbread Troubleshooting and Beginner Help 34 11-10-2009 01:21 PM
People Shooting into sun? KierraElizabeth Photo Critique 11 11-05-2009 11:06 PM
Shooting Into The Sun MightyMike Post Your Photos! 8 05-21-2009 06:44 AM
Shooting into the sun navcom Photographic Technique 21 09-20-2008 03:34 PM
Shooting at noon (full Sun). Any tips? drabina Photographic Technique 7 03-19-2008 11:51 AM
All times are GMT -7. The time now is 01:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
