Originally posted by Manel Brand: He didn't find my hint as serious one and deserving further inquiry (and maybe you don't either... Rest assured that I'm not crazy!)
and I really don't care that much about his fancy discoveries on the public library. I'm used and amused to listen to this kind of "surface scratch theories".
Manel, I did not at all dismiss the possibility that the rule of thirds and the golden ration are related. Your plot of thirds vs golden spiral is very suggestive!
On the other hand, classical "good" proportions are usually expressed as unit fractions. Vitruvius did so in his standard first-century book on architecture, it seems.
Consider that one of the canonical ways to front a public building is with a tetrastyle.
Its four columns divide the space into thirds horizontally.
What about vertical proportions? Bear with me, that's a stretch!! If the column spacing further follows the eustyle (and "eu" means "good" or "proper") conventions, then the space between the columns is 2 1/4 column diameters apart [Ref 1]. With an eyeballed cornice of about one-half column width [Ref 2], the total width of the building is giving 11 3/4 (or 12?) column diameters. Meanwhile, vertically, the recommended column height is 9 1/4 diameters [Ref 1]. If the architrave and frieze are each 1 column diameter [Ref 2], and there's a 1/2 diameter cornice [Ref 2: these are all eyeballed from the diagram], that gives a height of 11 3/4 column diameters. So far, so good -- the front is a square. How does it relate to a human being? Well, if the idea is to have two people walk side by side between the columns [Ref 1], that's a 2 1/2 "human width" column separation if we allow a bit of space between. Ah, so the columns are to be approximately 1 human width in diameter! What is the proportion of width to height in the "vitruvian man"? Well, his height is four cubits, his width at the shoulders one cubit [Ref 3]. And we've seen one cubit is one column diameter.
SO NOTE! The height of the buiding is twelve cubits (column diameters) = THREE TIMES the human height.
In other word a human being's head is at one-third the peristyle height.
We have a rule of thirds in architecture --vertically and horizontally -- that's at least FIRST CENTURY BC.
My references:
1.
Roman Architecture
2.
Entablature - Wikipedia, the free encyclopedia
3.
Vitruvian Man - Wikipedia, the free encyclopedia
Are these proportions an approximation to the golden spirals and their irrational ( 1 + Root 5) : 2 golden ratio? I don't see why they can't be, based on the little I know. The fact there seems to be a fudge factor (11.75 vs 12, etc.) is as suggestive as the fudge widths of the one-third lines in your diagrams.
In fact, the rule of thirds is just 1+2=3, right? Well, those are the numbers at the start of the sequence 1, 2, 3, 5, 8, 13, 21, 34, 55... where each number is the sum of the previous two. In the limit the ratio between successive numbers becomes exactly the golden ratio. That is, the rule of thirds is the first qpproximation to the golden ratio. I see no reason why it should not have been CONSCIOUSLY done this way, whenever it may have been.
Do the guidelines for photographic composition go back to the architectural canons? I imagine so, through the medium of European painting in the early modern period. I'm no expert in art history, but I do remember reading somewhere that when Western-style painting seeped through to Japan while it was still closed, the Japanese were very taken with the fact there were expected to be standard proportions within the painting.
Of course all this is precisely a scratch of the surface. Feel free to dismiss at will. Or is this part of the occult knowledge you're drawing on?
