Originally posted by RioRico I can't cite sources, just pass along some basics. The 'normal' focal length for any format is the diagonal of its frame. For a 5x7", that's 8.6" or ~220mm. A meniscus lens is totally uncorrected and will show aberrations. An achromat or anastigmat or other corrected lens will have less 'character' ie problems. You might check the Wikipedia entry on LENSES for more info.
Thank you for this. I forgot about the simplicity of measuring a format's diagonal to find the so-called "normal" focal length, although I had already found a few sources quoting the 190-220mm range as being adequate.
The other issue is determining the appropriate distance of the lens from the image plane of the receiving material, i.e. film/paper/etc. and I can't seem to find any resource for this. I know having a ground glass or some other visual aid would help. This is meant to be a simple construction, so I won't be buying a ground glass. There are things to consider like circles of confusion and diameter of the lens, but I'm hoping there's a simple way to divine the distance of lens-to-paper because we're talking about a single element.
