Originally posted by NYpHoToGraphEr Most likely is not going to work for me.
Ok let me rephrase this
does anyone have a k100d with a 50mm 1.4 lens?
Any Pentax made 35mm format, 50mm lens will work on a k100d, some will require an adapter, however.
But, since you just write "50mm 1.4" Then I have bad news because I have a 50mm f1.8 that doesnt work with my pentax. The lens is a Nikon though......
If you want to know if and if, then how well, a given 50mm lens will work on a given camera, then you need to say which 50mm lens it is, not just that it is a 50mm.
