Originally posted by lordson i've found anything below 35mm creates too much barrel distortion with the person's face
what the best focal length to take portraits with that lens?
and should i pony up for a 50mm 1.4? they're about $300AUD, which is alot of money
whats the best lens for taking portraits with? i would often be indoors in low light situations. i'm not even going to consider an external flash for the time being. although i know i should get one eventually for the portrait work.
cheers fellas
PS. do you guys have any tips for taking portraits? without a full on studio
This is what I've found out over the years.
1.) Use a lens you really like, and stick with it.
On my 35mm Canon, I would use either my 100 f2.8 or my 85 f1.8. Both were very good lenses, but I prefered to use the 85 at f2.0, f2.8 or f4.0. I, personally never liked using longer lenses for portraits, but that's just me. Experiment and see what you like.
As for digital, I just bought a 50-200, so I'll see how that works out. I'll probably be using it in the 50-70mm range. It may not be the sharpest lens out there, but I'm not concerned with razor-sharp portraits. (See # 7)
2.) Don't get too close. When I was younger, I would sometimes fill the frame with the person's face. When they saw the print, they would usually remark, "My, that's a real closeup!", which I soon realized meant that they didn't like it. Many people don't like very close pictures of themselves. I usually shoot 3/4 to mid-chest portraits.
3.) Don't cut off limbs at the joints. Either get the full leg, or crop between the knee and the ankle, the hip and the knee, but never right at the knee or elbow or right at the waist. I read this in a book once, and it worked for me.
4.) Try to shoot from slightly above the subject's eye level, so as not to give them a double chin. This I learned myself from screwing up a few early portraits.
5.) As for lighting, I always tried to avoid using fill flash. I prefered shooting in flat lighting, and using a reflector to add light where I wanted it. I never went for the bright, snappy-looking portrait, but rather tried to get my pictures to look as much like paintings as possible. Evening light high-lighting the hair and careful metering was my favorite approach, but naturally I couldn't always do this.
6.) Try using a darker, simpler background as opposed to a lighter, busier one to put more emphasis on the subject. A brick or stone wall or trees always looked better to me than an urban or scenic bachground, which I felt distracted the viewer from the subject. Wood is good! I think it adds a natural, rustic feel to a portrait.
7.) This is completely subjective: Use a soft-focus filter, especially for women, and sometimes for men as well. Which one to use? I would recommend either a Tiffen Soft-FX 1, 2 or 3 filter. Try both the regular and warm versions. All I can say is experiment, and see what you like, or rather what your subjects like best.
8.) Use a tripod whenever you can. Partly to avoid camera shake with slower shutter speeds, but almost as importantly to keep the same composition from shot to shot.
These are my general portrait taking rules, gleaned partly from books, partly from other, more experienced photographers giving me tips and partly from me learning from my mistakes over the years.
By the way, most of these recommendations are for outdoor portraits.
Good luck.
Mike
Here's an example of an available-light portrait taken in the shade of trees midday in July. Fill flash was used. Post exposure in camera digital soft filter effect added.
