I was reading this the other day:
Secrets of the Milky Way - Jim Richardson
"Fortunately, the Milky Way is always the same exposure: 90 seconds, f2.8, ISO 3200 will always get you a nice, bright Milky Way. Or, 60 seconds, f2.8, ISO 5000 will work. Or 30 seconds, f1.4, ISO 1600 works well, too. But note that there are no 14mm f1.4 lenses. There is one 24mm f1.4 lens and it can produce some fine star images, though with somewhat limited performance in the corners. The problem to be solved with that lens is getting it in focus, which is fiendishly difficult at f1.4 in total darkness. It must be absolutely in focus. (Hint: auto focus won’t even come close.)"
So with the K-5, I thought I can make it this time since ISO6400 is OK with K-5. I went to Assateague National Sea Shore camping and try out the starry night shot. I don't have a wide f2.8 lens (DA* 16-50mm on its way) so the kit lens is my only wide angle lens.
So my settings are ISO6400, f3.5, 18mm, manual focus @ infinity, 30secs exposure, SR off, and here is the result:
edited in LR3 to add contrast, saturation, and de-noise. For some reason dark-frame substitution were turned off.
So the question, how do I get a picture that give me more bright stars on the sky?
(like the one w/ the milky way given in the link...)
Thanks,
Lee
