Sorry, but much of this is shockingly bad advice.
Originally posted by Mr. The Guy
1. Ditch your filters. They hurt image quality.
A good UV filter, although not necessarily much good for reducing UV-induced colour casts, might possibly cause additional flare in some circumstances, and might cause a little extra vignetting at very wide angles. But to say "they hurt image quality", although technically true, will make a visible difference only in rare cases. By the same token, there is nothing wrong with not using a filter, protecting the lens from impact damage with the lens hood as mentioned. But frequent cleaning is not recommended either.
Quote: The only filter you should ever use when shooting digital is a circular polarizer. Good ones cost close to $200 but if you just put your sunglasses in front of you lens when it's really sunny, that works too.
And you're worried about image quality? This is hilarious.
Plenty of sunglasses are not polarised, in which case they'll act as neutral density filters. Plenty are coloured, in which case they'll act as coloured filters. However, they are not optically flat, and of course not usually the right shape or size. This is an extremely bad idea.
Incidentally, the K10D is just fine with a Linear Polariser, and I've seen claims that the K100D is as well. It would be worth trying one before spending money on a much more expensive Circular Polariser.
Quote: If you're a beginner, it is especially important you shoot RAW, not JPEG. JPEG is a sub-par format that only supports 8-bit colour.
This is just scare-mongering. In the vast majority of cases RAW will yield results no better than JPEG. A beginner is going to be much better off learning about composition and exposure, than worrying about the differences in detail recoverable from a RAW file than from the corresponding JPEG.
Quote: Also, if you make mistakes using RAW, the chances of you fixing the problems in post-processing are far greater.
This is only true if the exposure has not blown out the highlights. Once it's gone, it's gone.
Quote: If you're not using image stabilization, you have to shoot RAW and learn how to sharpen using counter-intuitively; 'unsharp mask'.
This is nonsense.
If you're not using shake reduction, camera-shake may indeed give you a blurred image. Shooting RAW will not affect this, and sharpening, so-called, does not remove blur, nor does it give you additional detail not captured by the exposure.
Quote: 7. You're not seeing sensor noise. In fact a K10D has a 'noisier' sensor.
While it is true that the K10D shows more noise at high ISO than the K100D, sensor noise can be seen at any ISO setting, in parts of an image that are underexposed. So you may well be seeing noise in some photos, at any ISO setting.
